이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip laptop over bottom side up.
Locate the two battery release switches.
Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
Locate the five black screws on the back.
Use a Phillips #0 screwdriver to remove all five black 6 mm screws.
Locate the three silver screws underneath the battery.
Use the Phillips #0 screwdriver to remove all three 4 mm screws.
Locate the four rubber stoppers near each corner of the laptop.
Open up the stopper with your hands.
Use the Phillips #0 screwdriver to remove the 6 mm screws underneath all four stoppers.
Locate the hard drive.
Use the Phillips #0 screwdriver to remove the two 4 mm screws that are holding the hard drive in place.
Once the hard drive is removed, locate the four screws that hold the metal frame to the hard drive.
Use the Phillips #0 screwdriver to remove the 4 mm silver screws on all sides.
