주요 콘텐츠로 건너뛰기
Lenovo Ideapad S415 Touch RAM Replacement
필요한 것
  1. Lenovo Ideapad S415 Touch RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch RAM Replacement: 2 단계, 이미지 1/1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch RAM Replacement: 3 단계, 이미지 1/1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch RAM Replacement: 4 단계, 이미지 1/1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch RAM Replacement: 5 단계, 이미지 1/1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch RAM Replacement, RAM: 6 단계, 이미지 1/2 Lenovo Ideapad S415 Touch RAM Replacement, RAM: 6 단계, 이미지 2/2
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five screws.
  7. Lenovo Ideapad S415 Touch RAM Replacement: 7 단계, 이미지 1/2 Lenovo Ideapad S415 Touch RAM Replacement: 7 단계, 이미지 2/2
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Use the Phillips #0 screwdriver to remove all three screws.
  8. Lenovo Ideapad S415 Touch RAM Replacement: 8 단계, 이미지 1/3 Lenovo Ideapad S415 Touch RAM Replacement: 8 단계, 이미지 2/3 Lenovo Ideapad S415 Touch RAM Replacement: 8 단계, 이미지 3/3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your hands.
  9. Lenovo Ideapad S415 Touch RAM Replacement: 9 단계, 이미지 1/3 Lenovo Ideapad S415 Touch RAM Replacement: 9 단계, 이미지 2/3 Lenovo Ideapad S415 Touch RAM Replacement: 9 단계, 이미지 3/3
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch RAM Replacement: 10 단계, 이미지 1/2 Lenovo Ideapad S415 Touch RAM Replacement: 10 단계, 이미지 2/2
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch RAM Replacement: 11 단계, 이미지 1/3 Lenovo Ideapad S415 Touch RAM Replacement: 11 단계, 이미지 2/3 Lenovo Ideapad S415 Touch RAM Replacement: 11 단계, 이미지 3/3
    • Locate the RAM.
    • Using your hands gently push up on the two silver clips located on both ends of the RAM.
    • The RAM will spring out. Gently pull it out of the slot.
    • Do not touch the top yellow part of the RAM as this will cause damage.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexandria
회원 가입일: 02/05/19
363 평판
안내서 2개 작성하였습니다
UC Davis, Team S20-G5, Lore Winter 2019 UC Davis, Team S20-G5, Lore Winter 2019 회원
UCD-LORE-W19S20G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 724
