이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip laptop over bottom side up.
Locate the two battery release switches.
Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
Locate the five 6mm black screws on the bottom.
Using a Phillips #0 screwdriver, remove all five screws.
Locate the three 4mm silver screws on the bottom area where the battery was removed.
Use the Phillips #0 screwdriver to remove all three screws.
Locate the four rubber stoppers near each corner of the laptop.
Open up the stoppers by lifting each with your hands.
Under each of the four stoppers, there will be a 6mm screw.
Use the Phillips #0 screwdriver to remove all four screws.
Locate the RAM.
Using your hands gently push up on the two silver clips located on both ends of the RAM.
The RAM will spring out. Gently pull it out of the slot.
다른 한 분이 해당 안내서를 완성하였습니다.
