주요 콘텐츠로 건너뛰기
Lenovo Ideapad Y700 15-ISK Hard Drive Replacement
필요한 것
  1. Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Preparing the laptop for disassembly.: 1 단계, 이미지 1/2 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Preparing the laptop for disassembly.: 1 단계, 이미지 2/2
    • Shut down the laptop.
    • Disconnect the power plug.
    • Close the laptop.
  2. Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Opening the back panel.: 2 단계, 이미지 1/3 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Opening the back panel.: 2 단계, 이미지 2/3 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Opening the back panel.: 2 단계, 이미지 3/3
    • Flip the laptop upside down.
    • Remove these 11 screws with a phillips screwdriver.
    • Remove the cover by putting something thin between the cover and the base and then pushing towards the cooling vents, carefully lift it.
  3. Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the disk from the laptop.: 3 단계, 이미지 1/2 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the disk from the laptop.: 3 단계, 이미지 2/2
    • Remove these 4 screws with a phillips screwdriver.
    • Uclip and disconnect the ribbon cable.
    • Remove the disk from the laptop.
  4. Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the bracket.: 4 단계, 이미지 1/3 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the bracket.: 4 단계, 이미지 2/3 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the bracket.: 4 단계, 이미지 3/3
    • Unplug the SATA adaptor from the disk.
    • Remove the disk from the bracket.
결론
The drive is out. To install a new one, just follow the steps in the opposite order.
다른 5명이 해당 안내서를 완성하였습니다.
Sebastian Szymański
회원 가입일: 11/14/16
333 평판
안내서 1개 작성함
댓글 6개
Friend, I tried to remove the cover after removing all the screws, but it seemed to be locked.
rpvale2002 - 답글
You need to carefully pry the bottom cover with something thin like a plastic pryer.
Sebastian Szymański -
My Y700 has two harddrives. Is this the instructions for the primary hard drive or the secondary?
klobpries - 답글
It’s possible that the second drive is a M.2 drive. Both can be either. It’s suggested to use the faster drive for the system and the slower one for storage.
Would Samsung 1TB SSD 860 EVO work for the HDD replacement ?
chou jason - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 58
전체 시간: 10,268
