주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If your speakers no longer work correctly, this guide will teach you how to remove the laptop's speaker.
  1. Begin by turning your closed laptop so that you are looking at the bottom panel.
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Locate the 10 screws (6mm) around the border of the panel. Using the Torx T5 Screwdriver, remove the screws.
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  3. Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
  4. Remove 2 screws (2mm) from each of the speakers, 4 screws total, using the PH #000 screwdriver. Remove 2 screws (2mm) from each of the speakers, 4 screws total, using the PH #000 screwdriver.
    • Remove 2 screws (2mm) from each of the speakers, 4 screws total, using the PH #000 screwdriver.
  5. Locate the connecting cables. Locate the connecting cables.
    • Locate the connecting cables.
  6. Unclip the cables by pulling downwards gently using tweezers. Unclip the cables by pulling downwards gently using tweezers.
    • Unclip the cables by pulling downwards gently using tweezers.
  7. After the cables are disconnected, remove the speakers by lifting the speakers up.
    • After the cables are disconnected, remove the speakers by lifting the speakers up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andria Chen
회원 가입일: 2017년 10월 17일
597 평판
안내서 5개 작성하였습니다
UC Santa Barbara, Team S1-G5, Weedon Fall 2017 UC Santa Barbara, Team S1-G5, Weedon Fall 2017 회원
UCSB-WEEDON-F17S1G5
5 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 156
