주요 콘텐츠로 건너뛰기
Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset)
필요한 것
동영상 개요
  1. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset), Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): 1 단계, 이미지 1/1
    • First of all you can try soft reset from the reset switch. This method does not delete the data from the tablet.
  2. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): 2 단계, 이미지 1/3 Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): 2 단계, 이미지 2/3 Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): 2 단계, 이미지 3/3
    • Now - hardware reset:
    • Switch off the tablet.
    • Press and hold at the same time Volume UP and Power keys.
    • When the System Recovery screen appears use the Volume Up/Down keys for navigation and the Power On key for OK.
    • Choose "wipe data / factory reset", "Yes -- delete all user data", "reboot system now".
  3. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): 3 단계, 이미지 1/1
    • That's all.
결론
다른 47명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 36개
If device is connected to charger that button combination doesn't work. It goes to hardware test menu.
Pekka Lounatvuori - 답글
How to reser chinese language lenova phone
With Chinese phones, you do not need to use other options, and there is no confirmation. The wipe simply starts, and completes by wiping your phone. Read more - http://www.gogorapid.com/how-to-reset-ch...
Rumal Roma - 답글
My lenovo a 1000 idea tab's display is gone....no bottom in work...how to reset or fix it
ashiquehossain15 - 답글
my lenovo s850 is on meta mode when i press vol down + power button and nothing appear when i press vol up + power button.. the thing is i've tried many button sequence but i just cat get into reset mode or cynogen mode.. :(
wooblegooble92 - 답글
My lenovo tab isnt working until it went to some sort of menu using volume buttons but then i actually pressed something and it went to a screen saying "Now send the package you want to apply to the device using adb sideload <filename>" how do i go back to the reboot menu
Albert Einstein - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 58
30일 전: 259
전체 시간: 400,826
