주요 콘텐츠로 건너뛰기
Lenovo Ideatab A1107 Front Camera Replacement
필요한 것
  1. Lenovo Ideatab A1107 Front Camera Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Lenovo Ideatab A1107 Front Camera Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
    • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
  2. Lenovo Ideatab A1107 Front Camera Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Ideatab A1107 Front Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
  3. Lenovo Ideatab A1107 Front Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Lift up and remove the interior casing to expose the inner components.
    • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
  4. Lenovo Ideatab A1107 Front Camera Replacement, Battery: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to remove the tape covering the battery's wiring.
  5. Lenovo Ideatab A1107 Front Camera Replacement: 5 단계, 이미지 2개 중 1개 Lenovo Ideatab A1107 Front Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Do not puncture the lithium-ion battery. Ruptured batteries can catch fire or explode.
    • Do not use metal tools to remove the battery wire. They present the risk of electrocution.
    • Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
  6. Lenovo Ideatab A1107 Front Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Wedge a plastic opening tool in between the battery and the internal components of the device.
    • Use the plastic opener tool to remove the battery from its casing.
  7. Lenovo Ideatab A1107 Front Camera Replacement, Screen: 7 단계, 이미지 1개 중 1개
    • Using you hands, lift off the digitizer.
  8. Lenovo Ideatab A1107 Front Camera Replacement: 8 단계, 이미지 2개 중 1개 Lenovo Ideatab A1107 Front Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the three screws that are 2.0 mm in length and have a 5.25 mm head width with a Phillips #00 screwdriver.
  9. Lenovo Ideatab A1107 Front Camera Replacement: 9 단계, 이미지 2개 중 1개 Lenovo Ideatab A1107 Front Camera Replacement: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a spudger to remove the plastic piece securing the zero insertion force (ZIF) cable connector.
    • Use tweezers to grasp the ribbon cable, then pull the cable to disconnect it from the device.
  10. Lenovo Ideatab A1107 Front Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Locate the black electrical tape strip on the side of the device.
    • Gently remove the tape from the device using the tweezers.
  11. Lenovo Ideatab A1107 Front Camera Replacement: 11 단계, 이미지 3개 중 1개 Lenovo Ideatab A1107 Front Camera Replacement: 11 단계, 이미지 3개 중 2개 Lenovo Ideatab A1107 Front Camera Replacement: 11 단계, 이미지 3개 중 3개
    • After removing the electric tape, gently lift up the green control panel.
    • Taking the tweezers, remove the ribbon cable from the control panel.
    • Once the ribbon cable is removed from the panel, the display should separate with ease.
  12. Lenovo Ideatab A1107 Front Camera Replacement, Front Camera: 12 단계, 이미지 2개 중 1개 Lenovo Ideatab A1107 Front Camera Replacement, Front Camera: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tweezers, pull and remove the front camera component.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Katherine Enders
회원 가입일: 01/18/17
445 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 180
