주요 콘텐츠로 건너뛰기
Lenovo Ideatab S6000 Battery Replacement
필요한 것
  1. Lenovo Ideatab S6000 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • These screens are held in place by glue that is hard to remove. Please take your time to ensure that that this step is done correctly.
  2. Lenovo Ideatab S6000 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the screws from both of the spots that were covered.
  3. Lenovo Ideatab S6000 Battery Replacement: 3 단계, 이미지 1/1
    • DO NOT USE A METAL TOOL FOR THIS.
    • Go all around the casing, prying the screen away from the backing with the spudger.
    • It will make a popping sound each time one of the lock tabs is disconnected.
    • Take your time as you move all around the device when prying the backing off.
  4. Lenovo Ideatab S6000 Battery Replacement: 4 단계, 이미지 1/1
    • Pull off the plastic that is covering the battery cable.
  5. Lenovo Ideatab S6000 Battery Replacement: 5 단계, 이미지 1/2 Lenovo Ideatab S6000 Battery Replacement: 5 단계, 이미지 2/2
    • Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
  6. Lenovo Ideatab S6000 Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery by grabbing the tab shown and pulling up.
    • The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Josiah Speed
회원 가입일: 09/22/14
965 평판
안내서 4개 작성하였습니다
USF Tampa, Team 10-4, Brown Fall 2014 USF Tampa, Team 10-4, Brown Fall 2014 회원
USFT-BROWN-F14S10G4
4 회원들
안내서 10개 작성하였습니다
댓글 5개
Does this guide apply to all variants of this model? The S6000L frame doesn't seem to pop away from the screen assembly the same way. Is there adhesive in any of the models?
Shelby Greenwall - 답글
Can you recommend a professional who can help replace my Lenovo S600 battery.
Niyi Popoola - 답글
The original Lenovo battery comes with the metal frame. In my case, the screw holes of the metal frame did not fit the screw holes of the base. Thus, I just pulled the new battery off its metal frame and just replaced the battery.
Joachim Keinert - 답글
Great information. Thanks, you're a peach!
steve - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 13,289
