소개
Guide the user in replacing the battery in order to fix power related problems of the Lenovo Ideatab S6000.
필요한 것
Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 5개
Does this guide apply to all variants of this model? The S6000L frame doesn't seem to pop away from the screen assembly the same way. Is there adhesive in any of the models?
Can you recommend a professional who can help replace my Lenovo S600 battery.
The original Lenovo battery comes with the metal frame. In my case, the screw holes of the metal frame did not fit the screw holes of the base. Thus, I just pulled the new battery off its metal frame and just replaced the battery.
It was helpful.
I little bit of heat goes a long way when taking off the speaker screens.
iHelpU.Tech - 답글
