주요 콘텐츠로 건너뛰기
Lenovo Legion 5 17ACH6H RAM Replacement
필요한 것
  1. Lenovo Legion 5 17ACH6H RAM Replacement, RAM: 1 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement, RAM: 1 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement, RAM: 1 단계, 이미지 3/3
    • Use the Phillips #1 screwdriver to remove the ten screws on the back panel.
    • Four 4.6 mm PH1 screws
    • Six 12.8 mm PH1 screws
  2. Lenovo Legion 5 17ACH6H RAM Replacement: 2 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 2 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 2 단계, 이미지 3/3
    • Insert the rounded side of the opening pick on the lower right of the back panel.
    • Apply light pressure downwards to release the clip.
    • Slide the opening pick along the lower back side of the panel to release the remaining clips.
  3. Lenovo Legion 5 17ACH6H RAM Replacement: 3 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 3 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 3 단계, 이미지 3/3
    • Insert the opening pick on the right side of the panel (along the ports) and slide it across to release the pins.
    • Repeat this step on the left side of the panel.
  4. Lenovo Legion 5 17ACH6H RAM Replacement: 4 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 4 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 4 단계, 이미지 3/3
    • Slide the pick in the vent near the USB C port.
    • Rotate the pick so it is on the top part of the vent.
    • Slide the pick across the top side of the vent
    • The laptop can be held vertically, so the process is much easier.
    • Repeat this step on the other side vent near the USB A port.
  5. Lenovo Legion 5 17ACH6H RAM Replacement: 5 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 5 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 5 단계, 이미지 3/3
    • Grab the back panel and lift it to remove it from the chassis.
    • Before completely lifting the back panel, the panel should be pushed a little bit away from you. This is to prevent the panel from getting stuck with the IO ports.
  6. Lenovo Legion 5 17ACH6H RAM Replacement: 6 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 6 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 6 단계, 이미지 3/3
    • Use the pointed tip of a spudger to carefully push on each side of the connector.
    • Use the flat side of the spudger at the top of the battery connector to completely push it out.
    • Pull the cable by the connector and not the wires to move it out of the way.
    • It is important to disconnect the battery since touching the components with the battery connected can short-circuit the device. This could cause damage to the components and yourself.
  7. Lenovo Legion 5 17ACH6H RAM Replacement: 7 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 7 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 7 단계, 이미지 3/3
    • Place the flat side of the spudger between the RAM shield (right) and the metal plate (left) at a 45-degree angle.
    • Pry open the bottom part of the metal plate by moving the spudger toward the RAM shield.
  8. Lenovo Legion 5 17ACH6H RAM Replacement: 8 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 8 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 8 단계, 이미지 3/3
    • Place the flat side of the spudger between the fan (right) and the metal plate (left).
    • Pry open the top part of the metal plate by moving the spudger toward the fan.
  9. Lenovo Legion 5 17ACH6H RAM Replacement: 9 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 9 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 9 단계, 이미지 3/3
    • Grab both sides of the metal plate to lift it off the clips.
  10. Lenovo Legion 5 17ACH6H RAM Replacement: 10 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 10 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 10 단계, 이미지 3/3
    • With both thumbs, push the clips outward.
    • Gently slide the RAM module out of the socket to remove it.
  11. Lenovo Legion 5 17ACH6H RAM Replacement: 11 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 11 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 11 단계, 이미지 3/3
    • Repeat step 10 to remove the top module.
    • The laptop was rotated 180 degrees, which is why it is facing the camera.
  12. Lenovo Legion 5 17ACH6H RAM Replacement: 12 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 12 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 12 단계, 이미지 3/3
    • Insert the RAM module at a 45-degree angle.
    • Make sure the module aligns with the slot. You can check by making sure the module pins' holes align with the slot.
    • With a finger on the top part of the module, push the RAM stick downward.
    • A click indicates that the module has been inserted successfully.
  13. Lenovo Legion 5 17ACH6H RAM Replacement: 13 단계, 이미지 1/3 Lenovo Legion 5 17ACH6H RAM Replacement: 13 단계, 이미지 2/3 Lenovo Legion 5 17ACH6H RAM Replacement: 13 단계, 이미지 3/3
    • Repeat step 12 to insert the top RAM module.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Arturo Moreno
회원 가입일: 10/24/23
253 평판
안내서 1개 작성함
CSU Los Angeles, Team 12-4, Ribeiro Fall 2023 CSU Los Angeles, Team 12-4, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S12G4
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 111
전체 시간: 874
