주요 콘텐츠로 건너뛰기
Lenovo Legion 5-15ACH6 SSD Replacement
필요한 것
  1. Lenovo Legion 5-15ACH6 SSD Replacement, SSD: 1 단계, 이미지 1/1
    • Prepare your work area on a flat surface.
    • Lay your laptop down with the back case facing up.
  2. Lenovo Legion 5-15ACH6 SSD Replacement: 2 단계, 이미지 1/1
    • Use a Philips #1 screwdriver to remove the six 11.1 mm on the back of the device.
    • Use a Philips #00 screwdriver to remove the four 4.1 mm screws on the back case.
  3. Lenovo Legion 5-15ACH6 SSD Replacement: 3 단계, 이미지 1/3 Lenovo Legion 5-15ACH6 SSD Replacement: 3 단계, 이미지 2/3 Lenovo Legion 5-15ACH6 SSD Replacement: 3 단계, 이미지 3/3
    • Starting from the back of the laptop slide your opening tool between the bottom cover and laptop chassis.
    • Run the opening tool along the seam to separate the bottom cover from the chassis.
    • Remove the bottom cover and place to the side.
  4. Lenovo Legion 5-15ACH6 SSD Replacement: 4 단계, 이미지 1/3 Lenovo Legion 5-15ACH6 SSD Replacement: 4 단계, 이미지 2/3 Lenovo Legion 5-15ACH6 SSD Replacement: 4 단계, 이미지 3/3
    • To disconnect the battery cable safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Always pull cables by their connectors and not the wires themselves.
    • Touching any electrical component with the battery plugged in can result in damage to the motherboard.
  5. Lenovo Legion 5-15ACH6 SSD Replacement: 5 단계, 이미지 1/2 Lenovo Legion 5-15ACH6 SSD Replacement: 5 단계, 이미지 2/2
    • Remove the three 4.1mm Phillips #00 screws holding the metal shield in place.
    • Remove the metal shield and place it to the side.
  6. Lenovo Legion 5-15ACH6 SSD Replacement: 6 단계, 이미지 1/1
    • Remove the single 4.1 mm Philips #00 screw holding the SSD in place.
    • Pull the SSD out and away from the socket.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Patrick Underwood
회원 가입일: 10/24/23
175 평판
안내서 1개 작성함
CSU Los Angeles, Team 12-5, Ribeiro Fall 2023 CSU Los Angeles, Team 12-5, Ribeiro Fall 2023 회원
CSULA-RIBEIRO-F23S12G5
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 87
전체 시간: 417
