소개
This guide will walk you through the steps on how to replace your Levono Legion y520 fan. In cases when your fan maybe overheating or not working you will need this guide. NOTE: There are a lot of wires. Be sure to keep track of where each one goes.
필요한 것
Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
거의 끝나갑니다!
결론
다른 9명이 해당 안내서를 완성하였습니다.
