주요 콘텐츠로 건너뛰기
Lenovo Legion Y520-15IKBN Fan Replacement
필요한 것
  1. Lenovo Legion Y520-15IKBN Fan Replacement, Base Panel: 1 단계, 이미지 1/2 Lenovo Legion Y520-15IKBN Fan Replacement, Base Panel: 1 단계, 이미지 2/2
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Fan Replacement: 2 단계, 이미지 1/1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Fan Replacement, Fan: 3 단계, 이미지 1/3 Lenovo Legion Y520-15IKBN Fan Replacement, Fan: 3 단계, 이미지 2/3 Lenovo Legion Y520-15IKBN Fan Replacement, Fan: 3 단계, 이미지 3/3
    • There is a piece of plastic covering part of the RAM and the fan. You will need to remove this to get to the fan.
    • Unplug the battery then, you will need to remove the four 4 mm screws around the fan using a Phillips #00 screwdriver.
  4. Lenovo Legion Y520-15IKBN Fan Replacement: 4 단계, 이미지 1/3 Lenovo Legion Y520-15IKBN Fan Replacement: 4 단계, 이미지 2/3 Lenovo Legion Y520-15IKBN Fan Replacement: 4 단계, 이미지 3/3
    • Unscrew all the screws then unplug the wires connected to the fan.
    • Once all the wires are unplugged from the fan, move the wires aside to get the fan.
  5. Lenovo Legion Y520-15IKBN Fan Replacement: 5 단계, 이미지 1/3 Lenovo Legion Y520-15IKBN Fan Replacement: 5 단계, 이미지 2/3 Lenovo Legion Y520-15IKBN Fan Replacement: 5 단계, 이미지 3/3
    • Lift the fan out of the laptop body.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Emilee
회원 가입일: 10/04/18
262 평판
안내서 1개 작성함
댓글 3개
Superb guide. thank you random citizen for creating this guide
Fikri Nur Nafi - 답글
Do I need to remove the fan if I want to clean it or add oil?
Ziro Hutt - 답글
Is there a way to open the fan to clean the dust from the blade ?
Apalagi08 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 47
전체 시간: 7,401
