주요 콘텐츠로 건너뛰기
Lenovo Legion Y520-15IKBN Hard Drive Replacement
필요한 것
  1. Lenovo Legion Y520-15IKBN Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Lenovo Legion Y520-15IKBN Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Remove the thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Hard Drive Replacement: 2 단계, 이미지 1/1
    • Flip the laptop on its side and use a spudger or a credit card to pry the bottom covering off. To get a better grip you may want to open the laptop slightly.
    • The bottom piece will make popping noises as it is pulled from the laptop.
    • When reassembling make sure that the bottom piece clicks back into place on all sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Hard Drive Replacement: 3 단계, 이미지 1/3 Lenovo Legion Y520-15IKBN Hard Drive Replacement: 3 단계, 이미지 2/3 Lenovo Legion Y520-15IKBN Hard Drive Replacement: 3 단계, 이미지 3/3
    • The hard drive is a white square located on the right side of your device.
    • Use a Phillips #00 screwdriver to remove four 4.0 mm screws holding the hard drive in place.
  4. Lenovo Legion Y520-15IKBN Hard Drive Replacement: 4 단계, 이미지 1/2 Lenovo Legion Y520-15IKBN Hard Drive Replacement: 4 단계, 이미지 2/2
    • Slide the hard drive from the device towards your right.
    • When reinstalling remember to slide the hard drive in from the right. Don't try to force it in from the front.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Naomi Williams
회원 가입일: 10/04/18
786 평판
안내서 2개 작성하였습니다
댓글 한 개
Hi,
does anyone know if replacing the 1TB hard disk with a 1TB SSD is possible? (I’m thinking in terms of cloning the whole disk: can I go for a 1TB SSD or do I need a bigger one? Do hidden partitions for restoring the system / this kind of stuff get copied correctly? Most tutorials online just copy the Windows partition: wouldn’t want to find out I can’t reset the system if needed.)
Cycy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 21
30일 전: 103
전체 시간: 11,555
