주요 콘텐츠로 건너뛰기
Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement
필요한 것
  1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: 1 단계, 이미지 1/3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: 1 단계, 이미지 2/3 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: 1 단계, 이미지 3/3
    • Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
    • When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it.
    • When reinstalling key, no spudger is needed. Just pop it into place with fingers.
  2. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: 2 단계, 이미지 1/2 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two.
    • With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • If the two plastic pieces come apart refer to the last picture, showing the orientation in which they should be connected.
    • For reinstallation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
결론
Kaylea
회원 가입일: 10/04/18
185 평판
안내서 1개 작성함
댓글 3개
This is only for the key caps, what about the keyboard itself?
Rick Montoya - 답글
I agree the video is mislabeled. You are not replacing the board just keys.
Pat Schutte - 답글
Please create a tutorial for keys with stabilizer like space bar and enter keys.
Affix - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 25
30일 전: 145
전체 시간: 10,413
