소개
This guide will show you how to replace the RAM in the Lenovo Legion 520-IKBN. You would replace the RAM if computer is acting slower than it is or if your startup screen is a black screen.
필요한 것
Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 3개
Hi, can i add any 8gb 2400mhz ddr4 kit bought online? or does it have to be a specific kind?
Thank you for the guide
Azim Hanif - 답글
Here’s a link for the compatible ones https://www.crucial.de/deu/de/upgrade-ko...
