주요 콘텐츠로 건너뛰기
Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement
필요한 것
  1. Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement, Base Panel: 1 단계, 이미지 1/2 Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement, Base Panel: 1 단계, 이미지 2/2
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement: 2 단계, 이미지 1/1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement, Battery: 3 단계, 이미지 1/2 Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  4. Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement: 4 단계, 이미지 1/2 Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  5. Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement: 5 단계, 이미지 1/1
    • Lift the battery up and out of the chassis.
  6. Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement, Touchpad Button Board: 6 단계, 이미지 1/1
    • Use a spudger or a clean fingernail to flip up the locking flap on the two ZIF connectors securing the touchpad button board to the motherboard and touchpad.
    • Once the flaps are in the unlocked position, use tweezers or your fingers to gently pull the cables out of their sockets using the blue pull tabs.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  7. Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement: 7 단계, 이미지 1/3 Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement: 7 단계, 이미지 2/3 Lenovo Legion Y520-15IKBN Touchpad Button Board Replacement: 7 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove two 6.5 mm screws from the blue touchpad button board.
    • Remove the touchpad button board.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
PeytonR
회원 가입일: 02/13/24
135 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 48
