주요 콘텐츠로 건너뛰기
Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement
필요한 것
  1. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Base Panel: 1 단계, 이미지 1/2 Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Base Panel: 1 단계, 이미지 2/2
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement, Wi-Fi  Card: 3 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
  4. Lenovo Legion Y520-15IKBN Wi-Fi Card Replacement: 4 단계, 이미지 1/1
    • Pull the Wi-Fi card directly out of its port.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 30
전체 시간: 520
