주요 콘텐츠로 건너뛰기
Lenovo Legion Y530-15ICH Fan Replacement
필요한 것
  1. Lenovo Legion Y530-15ICH Fan Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Fan Replacement: 2 단계, 이미지 1/2 Lenovo Legion Y530-15ICH Fan Replacement: 2 단계, 이미지 2/2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Fan Replacement, Fan: 3 단계, 이미지 1/2 Lenovo Legion Y530-15ICH Fan Replacement, Fan: 3 단계, 이미지 2/2
    • Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
    • Remove the plastic covering after the screws have been loosened.
    • Spring screws will stay attached to the cover.
  4. Lenovo Legion Y530-15ICH Fan Replacement: 4 단계, 이미지 1/1
    • Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
  5. Lenovo Legion Y530-15ICH Fan Replacement: 5 단계, 이미지 1/1
    • Unplug the wires connecting the two fans to the motherboard.
    • When doing this, tug carefully from side to side.
  6. Lenovo Legion Y530-15ICH Fan Replacement: 6 단계, 이미지 1/2 Lenovo Legion Y530-15ICH Fan Replacement: 6 단계, 이미지 2/2
    • Lift the fans out of their positions and remove them from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Kaylie Klausing
회원 가입일: 02/07/20
776 평판
안내서 6개 작성하였습니다
Cal Poly, Team S7-G1, Regan Winter 2020 Cal Poly, Team S7-G1, Regan Winter 2020 회원
CPSU-REGAN-W20S7G1
4 회원들
안내서 12개 작성하였습니다
댓글 4개
Thank you! Very clear and well photographed :)
Daniel Perez - 답글
Any recommended stores for the replacement fans?
Ivan Ramljak - 답글
Worked like a charm, thank you!!
Skyler Boyle - 답글
where can i get a good replacement please
peters pelumi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 36
30일 전: 162
전체 시간: 12,668
