주요 콘텐츠로 건너뛰기
Lenovo Legion Y530-15ICH Solid State Drive Replacement
필요한 것
  1. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Solid State Drive Replacement: 2 단계, 이미지 1/2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: 2 단계, 이미지 2/2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: 3 단계, 이미지 1/2 Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: 3 단계, 이미지 2/2
    • Do not remove the thermal pad.
    • Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
  4. Lenovo Legion Y530-15ICH Solid State Drive Replacement: 4 단계, 이미지 1/2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: 4 단계, 이미지 2/2
    • Carefully remove the SSD from its connector.
결론
Insert your new SSD into the connector. To reassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Kaylie Klausing
회원 가입일: 02/07/20
776 평판
안내서 6개 작성하였습니다
Cal Poly, Team S7-G1, Regan Winter 2020 Cal Poly, Team S7-G1, Regan Winter 2020 회원
CPSU-REGAN-W20S7G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 50
전체 시간: 5,033
