주요 콘텐츠로 건너뛰기
Lenovo Legion Y530-15ICH Speaker Replacement
필요한 것
  1. Lenovo Legion Y530-15ICH Speaker  Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Speaker  Replacement: 2 단계, 이미지 1/2 Lenovo Legion Y530-15ICH Speaker  Replacement: 2 단계, 이미지 2/2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Speaker  Replacement, Battery: 3 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Speaker  Replacement: 4 단계, 이미지 1/2 Lenovo Legion Y530-15ICH Speaker  Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
  5. Lenovo Legion Y530-15ICH Speaker  Replacement, Speaker: 5 단계, 이미지 1/1
    • Remove the five screws using the Phillips #0 screwdriver.
  6. Lenovo Legion Y530-15ICH Speaker  Replacement: 6 단계, 이미지 1/1
    • Gently peel up the copper adhesive.
  7. Lenovo Legion Y530-15ICH Speaker  Replacement: 7 단계, 이미지 1/1
    • Remove the speakers from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 46
전체 시간: 1,346
