주요 콘텐츠로 건너뛰기
Lenovo Legion Y530-15ICH Speaker Replacement
필요한 것
  1. Lenovo Legion Y530-15ICH Speaker  Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Speaker  Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Legion Y530-15ICH Speaker  Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Speaker  Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Speaker  Replacement: 4 단계, 이미지 2개 중 1개 Lenovo Legion Y530-15ICH Speaker  Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
  5. Lenovo Legion Y530-15ICH Speaker  Replacement, Speaker: 5 단계, 이미지 1개 중 1개
    • Remove the five screws using the Phillips #0 screwdriver.
  6. Lenovo Legion Y530-15ICH Speaker  Replacement: 6 단계, 이미지 1개 중 1개
    • Gently peel up the copper adhesive.
  7. Lenovo Legion Y530-15ICH Speaker  Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the speakers from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 13
지난 30일: 42
전체 시간: 2,007
