주요 콘텐츠로 건너뛰기
Lenovo Legion Y530-15ICH USB Port Replacement
필요한 것
  1. Lenovo Legion Y530-15ICH USB Port Replacement, Back Cover: 1 단계, 이미지 1/1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH USB Port Replacement: 2 단계, 이미지 1/2 Lenovo Legion Y530-15ICH USB Port Replacement: 2 단계, 이미지 2/2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: 3 단계, 이미지 1/2 Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: 3 단계, 이미지 2/2
    • Remove the ribbon cable connecting the USB port to the motherboard, located adjacent to the fan unit.
    • Using a JIS #1 screwdriver, remove the two screws securing the USB port to the module.
  4. Lenovo Legion Y530-15ICH USB Port Replacement: 4 단계, 이미지 1/1
    • Gently disconnect the single ribbon cable with your fingers.
    • Remove the USB port from the device.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 19
전체 시간: 964
