주요 콘텐츠로 건너뛰기
Lenovo Legion Y7000P Back Cover Replacement
필요한 것
  1. Lenovo Legion Y7000P Back Cover Replacement, Flip your laptop over: 1 단계, 이미지 1/1
    • Flip your laptop over so the rubber feet are facing up.
  2. Lenovo Legion Y7000P Back Cover Replacement, Unfasten the back cover: 2 단계, 이미지 1/2 Lenovo Legion Y7000P Back Cover Replacement, Unfasten the back cover: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
    • Five 11.5 mm‑long screws
    • Six 4.7 mm-long screws
  3. Lenovo Legion Y7000P Back Cover Replacement, Insert an opening pick: 3 단계, 이미지 1/2 Lenovo Legion Y7000P Back Cover Replacement, Insert an opening pick: 3 단계, 이미지 2/2
    • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
  4. Lenovo Legion Y7000P Back Cover Replacement, Release the back cover's clips: 4 단계, 이미지 1/3 Lenovo Legion Y7000P Back Cover Replacement, Release the back cover's clips: 4 단계, 이미지 2/3 Lenovo Legion Y7000P Back Cover Replacement, Release the back cover's clips: 4 단계, 이미지 3/3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Keep the pick angled upwards while sliding to help release the clips.
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  5. Lenovo Legion Y7000P Back Cover Replacement: 5 단계, 이미지 1/3 Lenovo Legion Y7000P Back Cover Replacement: 5 단계, 이미지 2/3 Lenovo Legion Y7000P Back Cover Replacement: 5 단계, 이미지 3/3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  6. Lenovo Legion Y7000P Back Cover Replacement, Remove the back cover: 6 단계, 이미지 1/3 Lenovo Legion Y7000P Back Cover Replacement, Remove the back cover: 6 단계, 이미지 2/3 Lenovo Legion Y7000P Back Cover Replacement, Remove the back cover: 6 단계, 이미지 3/3
    • Remove the back cover.
  7. Lenovo Legion Y7000P Back Cover Replacement, Reassembly information: 7 단계, 이미지 1/3 Lenovo Legion Y7000P Back Cover Replacement, Reassembly information: 7 단계, 이미지 2/3 Lenovo Legion Y7000P Back Cover Replacement, Reassembly information: 7 단계, 이미지 3/3
    • During reassembly:
    • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
    • Press down firmly around the perimeter of the back cover to engage all the clips.
결론
Spencer Day
회원 가입일: 09/14/22
54,989 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,303개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 135
