주요 콘텐츠로 건너뛰기
Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement
필요한 것
  1. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, W-Fi Card: 1 단계, 이미지 1/3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, W-Fi Card: 1 단계, 이미지 2/3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, W-Fi Card: 1 단계, 이미지 3/3
    • Using the Phillips #00 screws, remove 13 screws from the backside of the laptop.
    • Five 2x1/2 screws.
    • Eight 1x1/2 screws.
  2. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Pry open the back cover open with a plastic opening tool.
  3. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Carefully remove the taped on paper under the fans.
  4. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 4 단계, 이미지 1/3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 4 단계, 이미지 2/3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 4 단계, 이미지 3/3
    • Remove the four screws that are holding the battery down using a Phillips #00 screwdriver.
    • Disconnect and remove the battery from the device.
  5. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 5 단계, 이미지 1/3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 5 단계, 이미지 2/3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 5 단계, 이미지 3/3
    • Using a plastic opening tool, carefully disconnect the two cables connected to the Wi-Fi card.
  6. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 6 단계, 이미지 1/3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 6 단계, 이미지 2/3 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: 6 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, remove the screw holding the Wi-Fi card to the device.
    • Remove the Wi-Fi Card from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lawrence Lam
회원 가입일: 10/20/20
204 평판
안내서 1개 작성함
CSU Los Angeles, Team S12-G18, Harris Fall 2020 CSU Los Angeles, Team S12-G18, Harris Fall 2020 회원
CSULA-HARRIS-F20S12G18
1 회원
안내서 1개 작성하였습니다
댓글 3개
Thanks for the guide Lawrence, can I ask what card you replaced the stock one with?
mkrnblack - 답글
I reccomend using the Wireless AC 8265 with bluetooth. There is the one I bought:
Intel Dual Band Wireless-Ac 8265... https://www.amazon.com/dp/B01MZA1AB2?ref...
Hope it goes well for you, it should fix all the ping spikes and unstable internet from the stock lenovo wifi chip.
Lawrence Lam -
Thanks for the recommendation I originally went with the 9560.NGWG.NV but It was not an improvement, in fact it might be worse. So I will try the 8265.
mkrnblack - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 1,385
