주요 콘텐츠로 건너뛰기
Lenovo Miix 2 Battery Replacement
필요한 것
  1. Lenovo Miix 2 Battery Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Miix 2 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Battery Replacement: 2 단계, 이미지 1/2 Lenovo Miix 2 Battery Replacement: 2 단계, 이미지 2/2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Battery Replacement: 3 단계, 이미지 1/2 Lenovo Miix 2 Battery Replacement: 3 단계, 이미지 2/2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Battery Replacement: 4 단계, 이미지 1/2 Lenovo Miix 2 Battery Replacement: 4 단계, 이미지 2/2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nicolas Jones
회원 가입일: 04/14/15
395 평판
안내서 1개 작성함
Cal Poly, Team 5-8, Maness Spring 2015 Cal Poly, Team 5-8, Maness Spring 2015 회원
CPSU-MANESS-S15S5G8
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 34
전체 시간: 8,921
