주요 콘텐츠로 건너뛰기
Lenovo Miix 2 External Buttons on Back Cover Replacement
필요한 것
  1. Lenovo Miix 2 External Buttons on Back Cover Replacement, External Buttons on Back Cover: 1 단계, 이미지 1/1
    • Gently insert metal spudger into back panel of the device.
    • Remove the back cover with your hand.
  2. Lenovo Miix 2 External Buttons on Back Cover Replacement: 2 단계, 이미지 1/3 Lenovo Miix 2 External Buttons on Back Cover Replacement: 2 단계, 이미지 2/3 Lenovo Miix 2 External Buttons on Back Cover Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using the tweezers remove the volume button located towards the top of the device, near the rear camera cut out.
    • Next, gently lift up on the power button, once again using the tweezers, which is located above the volume button along the same side of the device.
결론
Max Rozema
회원 가입일: 04/02/19
157 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G1, Harley Spring 2019 IUPUI, Team S3-G1, Harley Spring 2019 회원
IUPUI-HARLEY-S19S3G1
3 회원들
안내서 2개 작성하였습니다
댓글 한 개
pleas i need the Lenovo Miix 2 External Buttons on Back Cover how to find it it's has part nomber help me pls.
Ahmed Almaiman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 344
