주요 콘텐츠로 건너뛰기
Lenovo Miix 2 Front Facing Camera Replacement
필요한 것
  1. Lenovo Miix 2 Front Facing Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Front Facing Camera Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Front Facing Camera Replacement: 3 단계, 이미지 2개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Front Facing Camera Replacement: 4 단계, 이미지 2개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Lenovo Miix 2 Front Facing Camera Replacement, Speakers: 5 단계, 이미지 2개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement, Speakers: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
    • To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
  6. Lenovo Miix 2 Front Facing Camera Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    • Locate the LCD cable connector and gently pry it directly up with a spudger.
  7. Lenovo Miix 2 Front Facing Camera Replacement: 7 단계, 이미지 3개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement: 7 단계, 이미지 3개 중 2개 Lenovo Miix 2 Front Facing Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 5 ribbon cables. use the tip of the spudger to flip up the retaining flap, making sure to lift on the hinge and not the connector itself, then remove the cable from the connector.
    • The flaps and connectors vary in color.
    • Once the hinge has been lifted, the ribbon cable should take no force to remove.
  8. Lenovo Miix 2 Front Facing Camera Replacement: 8 단계, 이미지 2개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the 3 antenna cables using the tweezers by slowly pulling up.
    • We found that pulling up and twisting a bit works best.
  9. Lenovo Miix 2 Front Facing Camera Replacement: 9 단계, 이미지 2개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the 4 1.6mm screws with a J0 head.
  10. Lenovo Miix 2 Front Facing Camera Replacement: 10 단계, 이미지 2개 중 1개 Lenovo Miix 2 Front Facing Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the red and black cable using the tweezers by gently pulling the connector to the right.
  11. Lenovo Miix 2 Front Facing Camera Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the motherboard out of the tablet's case.
  12. Lenovo Miix 2 Front Facing Camera Replacement, Front Facing Camera: 12 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Disconnect the ribbon cable using the tweezers
  13. Lenovo Miix 2 Front Facing Camera Replacement: 13 단계, 이미지 1개 중 1개
    • Lift the camera up with tweezers to remove it
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Diana Chiu
회원 가입일: 07/14/14
654 평판
안내서 4개를 작성함
Cal Poly, Team 5-8, Maness Spring 2015 Cal Poly, Team 5-8, Maness Spring 2015 회원
CPSU-MANESS-S15S5G8
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 2,002
