주요 콘텐츠로 건너뛰기
Lenovo Miix 2 Speakers Replacement
필요한 것
  1. Lenovo Miix 2 Speakers Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Miix 2 Speakers Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Speakers Replacement: 2 단계, 이미지 1/2 Lenovo Miix 2 Speakers Replacement: 2 단계, 이미지 2/2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Speakers Replacement: 3 단계, 이미지 1/2 Lenovo Miix 2 Speakers Replacement: 3 단계, 이미지 2/2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Speakers Replacement: 4 단계, 이미지 1/2 Lenovo Miix 2 Speakers Replacement: 4 단계, 이미지 2/2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Lenovo Miix 2 Speakers Replacement, Speakers: 5 단계, 이미지 1/2 Lenovo Miix 2 Speakers Replacement, Speakers: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the red and black connector cable linking the speakers to the motherboard with tweezers by pulling the connector to the left with a light degree of force.
    • To properly remove the speakers from the casing, push gently left until it shifts, then pull directly up.
결론
Diana Chiu
회원 가입일: 07/14/14
654 평판
안내서 4개 작성하였습니다
Kid fixers Kid fixers 회원
Community
162 회원들
안내서 300개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 957
