주요 콘텐츠로 건너뛰기
Lenovo Miix 2 Vibrating Cable Replacement
필요한 것
  1. Lenovo Miix 2 Vibrating Cable Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo Miix 2 Vibrating Cable Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Vibrating Cable Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Miix 2 Vibrating Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Vibrating Cable Replacement: 3 단계, 이미지 2개 중 1개 Lenovo Miix 2 Vibrating Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Vibrating Cable Replacement: 4 단계, 이미지 2개 중 1개 Lenovo Miix 2 Vibrating Cable Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the battery by prying up with your fingers or a plastic opening tool.
  5. Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: 5 단계, 이미지 3개 중 1개 Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: 5 단계, 이미지 3개 중 2개 Lenovo Miix 2 Vibrating Cable Replacement, Vibrating Cable: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the vibrator cable which is connected with a white connector head to the motherboard, by gently lifting on the connector head with tweezers.
    • Remove the vibrator head by following the black and wire cable from the motherboard to where the head is located.
결론
작성자
2다른 기여자 명과 함께
Max Rozema
회원 가입일: 04/02/19
157 평판
안내서 2개를 작성함
IUPUI, Team S3-G1, Harley Spring 2019 IUPUI, Team S3-G1, Harley Spring 2019 회원
IUPUI-HARLEY-S19S3G1
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 309
