주요 콘텐츠로 건너뛰기
Lenovo N20p Chromebook Keyboard Replacement
필요한 것
  1. Lenovo N20p Chromebook Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Lenovo N20p Chromebook Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook Keyboard Replacement: 2 단계, 이미지 1/2 Lenovo N20p Chromebook Keyboard Replacement: 2 단계, 이미지 2/2
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook Keyboard Replacement: 3 단계, 이미지 1/3 Lenovo N20p Chromebook Keyboard Replacement: 3 단계, 이미지 2/3 Lenovo N20p Chromebook Keyboard Replacement: 3 단계, 이미지 3/3
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
결론
Shihao Cao
회원 가입일: 07/12/18
497 평판
안내서 4개 작성하였습니다
UW Tacoma, Team S1-G2, Cardinal Summer 2018 UW Tacoma, Team S1-G2, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 13
전체 시간: 277
