주요 콘텐츠로 건너뛰기
Lenovo N21 Chromebook Battery Replacement
필요한 것
  1. Lenovo N21 Chromebook Battery Replacement, Keyboard and Trackpad Panel: 1 단계, 이미지 1/2 Lenovo N21 Chromebook Battery Replacement, Keyboard and Trackpad Panel: 1 단계, 이미지 2/2
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
  2. Lenovo N21 Chromebook Battery Replacement: 2 단계, 이미지 1/2 Lenovo N21 Chromebook Battery Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Lenovo N21 Chromebook Battery Replacement: 3 단계, 이미지 1/2 Lenovo N21 Chromebook Battery Replacement: 3 단계, 이미지 2/2
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Lenovo N21 Chromebook Battery Replacement: 4 단계, 이미지 1/3 Lenovo N21 Chromebook Battery Replacement: 4 단계, 이미지 2/3 Lenovo N21 Chromebook Battery Replacement: 4 단계, 이미지 3/3
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Lenovo N21 Chromebook Battery Replacement: 5 단계, 이미지 1/2 Lenovo N21 Chromebook Battery Replacement: 5 단계, 이미지 2/2
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Lenovo N21 Chromebook Battery Replacement: 6 단계, 이미지 1/3 Lenovo N21 Chromebook Battery Replacement: 6 단계, 이미지 2/3 Lenovo N21 Chromebook Battery Replacement: 6 단계, 이미지 3/3
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  7. Lenovo N21 Chromebook Battery Replacement: 7 단계, 이미지 1/1
    • Remove the keyboard and trackpad panel away from the device.
  8. Lenovo N21 Chromebook Battery Replacement, Battery: 8 단계, 이미지 1/3 Lenovo N21 Chromebook Battery Replacement, Battery: 8 단계, 이미지 2/3 Lenovo N21 Chromebook Battery Replacement, Battery: 8 단계, 이미지 3/3
    • Disconnect the white charging cable connectors by pulling straight down on the connector.
  9. Lenovo N21 Chromebook Battery Replacement: 9 단계, 이미지 1/2 Lenovo N21 Chromebook Battery Replacement: 9 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the three 3mm screws located along the edge of the battery.
  10. Lenovo N21 Chromebook Battery Replacement: 10 단계, 이미지 1/1
    • Peel up on the silver cable enough to remove the adhesive to the battery.
    • When moving the adhesive cable, be careful not to disconnect or damage the cable and motherboard.
  11. Lenovo N21 Chromebook Battery Replacement: 11 단계, 이미지 1/1
    • Remove the battery by pulling back and up.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jacob Taylor
회원 가입일: 04/26/17
260 평판
안내서 1개 작성함
Cal Poly, Team S21-G2, Livingston Spring 2017 Cal Poly, Team S21-G2, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G2
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Great step by step instructions!
M Mikusa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 9,008
