소개
Once the keyboard and touch pad have been removed, the battery can be easily replaced by removing three screws and a connection cable.
필요한 것
Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
Disconnect the white charging cable connectors by pulling straight down on the connector.
거의 끝나갑니다!
결론
다른 7명이 해당 안내서를 완성하였습니다.
