주요 콘텐츠로 건너뛰기
Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement
필요한 것
  1. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement, Keyboard and Trackpad Panel: 1 단계, 이미지 1/2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement, Keyboard and Trackpad Panel: 1 단계, 이미지 2/2
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
  2. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 2 단계, 이미지 1/2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 3 단계, 이미지 1/2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 3 단계, 이미지 2/2
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 4 단계, 이미지 1/3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 4 단계, 이미지 2/3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 4 단계, 이미지 3/3
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 5 단계, 이미지 1/2 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 5 단계, 이미지 2/2
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 6 단계, 이미지 1/3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 6 단계, 이미지 2/3 Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 6 단계, 이미지 3/3
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  7. Lenovo N21 Chromebook Keyboard and Trackpad Panel Replacement: 7 단계, 이미지 1/1
    • Remove the keyboard and trackpad panel away from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Alex Cass
회원 가입일: 04/26/17
285 평판
안내서 2개 작성하였습니다
Cal Poly, Team S21-G2, Livingston Spring 2017 Cal Poly, Team S21-G2, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 2,207
