주요 콘텐츠로 건너뛰기
Lenovo N21 Chromebook WiFi Card Replacement
필요한 것
  1. Lenovo N21 Chromebook WiFi Card Replacement, Keyboard and Trackpad Panel: 1 단계, 이미지 1/2 Lenovo N21 Chromebook WiFi Card Replacement, Keyboard and Trackpad Panel: 1 단계, 이미지 2/2
    • Power down the Chromebook before starting any repair.
    • Opening up your Chromebook voids the manufacturer warranty.
    • Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
  2. Lenovo N21 Chromebook WiFi Card Replacement: 2 단계, 이미지 1/2 Lenovo N21 Chromebook WiFi Card Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry off the four rubber pegs from the bottom housing.
  3. Lenovo N21 Chromebook WiFi Card Replacement: 3 단계, 이미지 1/2 Lenovo N21 Chromebook WiFi Card Replacement: 3 단계, 이미지 2/2
    • Use a screwdriver to remove the four 5.0mm Phillips screws located under the rubber soles.
  4. Lenovo N21 Chromebook WiFi Card Replacement: 4 단계, 이미지 1/3 Lenovo N21 Chromebook WiFi Card Replacement: 4 단계, 이미지 2/3 Lenovo N21 Chromebook WiFi Card Replacement: 4 단계, 이미지 3/3
    • Flip the laptop over and open the screen.
    • Gently pry the keyboard and trackpad panel away from the bottom housing using a plastic opening tool.
    • Once completely separated, do not immediately pull the panel completely away from the bottom housing. There are wires that are still connecting the panel to the rest of the internals of the Chromebook.
  5. Lenovo N21 Chromebook WiFi Card Replacement: 5 단계, 이미지 1/2 Lenovo N21 Chromebook WiFi Card Replacement: 5 단계, 이미지 2/2
    • Disconnect the keyboard ribbon cable by lifting the ZIF connector lock with a plastic opening tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  6. Lenovo N21 Chromebook WiFi Card Replacement: 6 단계, 이미지 1/3 Lenovo N21 Chromebook WiFi Card Replacement: 6 단계, 이미지 2/3 Lenovo N21 Chromebook WiFi Card Replacement: 6 단계, 이미지 3/3
    • Disconnect the trackpad ribbon cable by lifting the ZIF connector lock with a small prying tool or fingernail and gently pulling the ribbon cable straight out of its socket.
  7. Lenovo N21 Chromebook WiFi Card Replacement: 7 단계, 이미지 1/1
    • Remove the keyboard and trackpad panel away from the device.
  8. Lenovo N21 Chromebook WiFi Card Replacement, WiFi Card: 8 단계, 이미지 1/2 Lenovo N21 Chromebook WiFi Card Replacement, WiFi Card: 8 단계, 이미지 2/2
    • Use a screwdriver to remove the single 3mm Phillips screw that is holding the WiFi card in place.
  9. Lenovo N21 Chromebook WiFi Card Replacement: 9 단계, 이미지 1/2 Lenovo N21 Chromebook WiFi Card Replacement: 9 단계, 이미지 2/2
    • Remove the black and white wires attached to WiFi card by gently lifting them upwards.
    • When re-attaching the wires, make sure they are in the correct placement. You do not want to switch the black and white wires.
  10. Lenovo N21 Chromebook WiFi Card Replacement: 10 단계, 이미지 1/2 Lenovo N21 Chromebook WiFi Card Replacement: 10 단계, 이미지 2/2
    • Remove the WiFi card by pulling it straight out of its connector.
    • Keep the WiFi card horizontal and pull straight back to avoid causing the part harm.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Alex Cass
회원 가입일: 04/26/17
285 평판
안내서 2개 작성하였습니다
Cal Poly, Team S21-G2, Livingston Spring 2017 Cal Poly, Team S21-G2, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G2
4 회원들
안내서 12개 작성하였습니다
댓글 5개
Very nicely written. Pictures are helpful too.
Adil M. - 답글
Thank you for this!
I had a Lenovo N21 Chromebook and the wifi card seemed to be faulty, but all it needed was a wipe off and It works perfectly now!
Evergreen - 답글
My Lenovo N21 was dropping the wifi connection. It did it a year ago and then improved, but the past month started doing it again very bad to the point I started looking for a replacement. It would maintain the connection for 5 minutes to 1 hour. I searched the problem, found this advise, and in 10 minutes it is fixed and has not dropped in 2 days. I assume it is fixed for good. Thanks for the tip and excellent instructions. Saved me $300 also.
Kerry Dalton - 답글
Kerry Dalton - what did you do to fix your problem? Replace? B & W wires crossed?
Im getting ready to take this device apart.
ssdrtelcom@gmail.com
Skip Stringham - 답글
I’ve replaced network cards in laptops before, so I’m not totally new at this, but from your diagram, my Lenovo 100e looks TOTALLY different. Has anyone had this issue? I can’t seem to find my network card. Or, is it integrated??
Eric R. Klingsten - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 39
전체 시간: 3,607
