주요 콘텐츠로 건너뛰기
Lenovo N22 Chromebook Individual Key Replacement
필요한 것
  1. Lenovo N22 Chromebook Individual Key Replacement, Individual Key: 1 단계, 이미지 1/1
    • Power down the chromebook before starting this process.
    • Loosen the key by prying on the edge of the key with the plastic opening tool.
  2. Lenovo N22 Chromebook Individual Key Replacement: 2 단계, 이미지 1/2 Lenovo N22 Chromebook Individual Key Replacement: 2 단계, 이미지 2/2
    • Remove the key from the keyboard by prying the key off with the opener or with your finger.
    • The key is connected to the keyboard with two connecting plastic squares. One is connected to the keyboard by tabs and one is connected to the keyboard by snaps.
    • When reassembling make sure that the two plastic square connectors are in the same place as when you removed the key.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Jackson Tucker
회원 가입일: 04/26/17
869 평판
안내서 3개 작성하였습니다
Cal Poly, Team S21-G1, Livingston Spring 2017 Cal Poly, Team S21-G1, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G1
4 회원들
안내서 14개 작성하였습니다
댓글 6개
very vague info. If a Key does not work and I take it out, why should it work once back in?? what do I need to change or look for? seems like very good instructions to take the keys out of a notebook
edperalt - 답글
Where can I order individual keys?
Mallory Montreuil - 답글
He tried to turn it on but it did not work
Clayton Sensing - 답글
I took it off and now it broken he he
BRENNEN FIRKUS - 답글
Yeah so I tried this on my computer to clean my keys and now my alt key won’t go back in. I also got my g key partially stuck in so only the right side of it works. Is there anything I am supposed to do?
Anushka Halepet - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 50
전체 시간: 14,588
