주요 콘텐츠로 건너뛰기
Lenovo N22 Chromebook Keyboard Replacement
필요한 것
  1. Lenovo N22 Chromebook Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Lenovo N22 Chromebook Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Keyboard Replacement: 2 단계, 이미지 1/3 Lenovo N22 Chromebook Keyboard Replacement: 2 단계, 이미지 2/3 Lenovo N22 Chromebook Keyboard Replacement: 2 단계, 이미지 3/3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo N22 Chromebook Keyboard Replacement: 3 단계, 이미지 2/2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Keyboard Replacement: 4 단계, 이미지 1/1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Jackson Tucker
회원 가입일: 04/26/17
869 평판
안내서 3개 작성하였습니다
Cal Poly, Team S21-G1, Livingston Spring 2017 Cal Poly, Team S21-G1, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G1
4 회원들
안내서 14개 작성하였습니다
댓글 6개
I have this laptop. The top right corner of the keyboard has popped out. How do I fix this?
Michael Faherty - 답글
Try removing the rubber foot under the popped corner, remove the screw, push down on the corner and replace the screw while holding the corner down.
Craig Carlson -
Just a note: the little rubber feet are all lettered (A-D) and you do need to match them to their proper corners when re-assembling.
Craig Carlson -
I have several keys that have stopped working. Replace the keyboard or is there a fix?
Richard Williams - 답글
This happen when the ribbon cable that connects the keyboard gets squashed too hard.
See [1] below for a decription and fix.
[1] https://forums.lenovo.com/t5/Lenovo-Chro...
Jan -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 63
전체 시간: 13,762
