소개
Through this guide, you will be able to remove the Chromebook's keyboard from the back casing and expose the battery and motherboard underneath. The keyboard may need to be replaced if several keys are unresponsive, the keyboard as a whole is unresponsive, or the mouse/touchpad is unresponsive.
필요한 것
Power Down the Chromebook before starting the repair
Opening the Chromebook voids the manufacturer warranty
Flip the Chromebook so that the bottom is facing upwards
Use a Phillips #1 screwdriver to remove the eight 6.6 mm screws in the bottom.
Flip the Chromebook over and open the screen
Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook
Be careful of the tabs on the inside of the keyboard and Chromebook, be cautious or these could break, too
Run the plastic tool along the seam, popping up the keyboard until you can freely lift up the keyboard
It is normal for the tabs to make a loud popping sounds when released. The corner tabs are harder to remove and will make a louder click when released.
Once the keyboard is released, grab the top two corners closest to the screen and slowly lift the keyboard up
Do not lift the keyboard too quickly, or you might break the two cables that connect the keyboard to the motherboard
The motherboard is now exposed DO NOT use any tools with metal, you may short circuit and fry the motherboard
Disconnect the cables by lifting up on the retaining tabs on the blank ZIF connectors
Slowly pull the cables up and out of the connectors
다른 2명이 해당 안내서를 완성하였습니다.
