주요 콘텐츠로 건너뛰기
Lenovo N23 Yoga Keyboard Replacement
필요한 것
  1. Lenovo N23 Yoga Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Lenovo N23 Yoga Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Lenovo N23 Yoga Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Flip the computer over.
    • Remove the 9 screws surrounding the edges of the computer.
    • Remove the single screw near the center of the computer.
  2. Lenovo N23 Yoga Keyboard Replacement: 2 단계, 이미지 1/1
    • Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
    • Slowly work your way around the edges of the computer.
    • Closer to the screen the clips will be sturdier, use a little more force but still be cautious.
  3. Lenovo N23 Yoga Keyboard Replacement: 3 단계, 이미지 1/1
    • On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
    • Remove the ribbon connectors gently from the main board.
  4. Lenovo N23 Yoga Keyboard Replacement: 4 단계, 이미지 1/1
    • The keyboard should be free and disconnected from the rest of the computer.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Drew Canada
회원 가입일: 04/03/18
1,370 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,529
