이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the computer over.
Remove the 9 screws surrounding the edges of the computer.
Remove the single screw near the center of the computer.
Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
Slowly work your way around the edges of the computer.
Closer to the screen the clips will be sturdier, use a little more force but still be cautious.
On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
Remove the ribbon connectors gently from the main board.
The keyboard should be free and disconnected from the rest of the computer.
다른 2명이 해당 안내서를 완성하였습니다.
