주요 콘텐츠로 건너뛰기
Lenovo S20-30 Keyboard Replacement
필요한 것
  1. Lenovo S20-30 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Keyboard Replacement: 2 단계, 이미지 1/1
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo S20-30 Keyboard Replacement: 3 단계, 이미지 2/2
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/3 Lenovo S20-30 Keyboard Replacement, Keyboard: 4 단계, 이미지 2/3 Lenovo S20-30 Keyboard Replacement, Keyboard: 4 단계, 이미지 3/3
    • Remove the two front rubber feet using a long metal spudger.
    • Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
  5. Lenovo S20-30 Keyboard Replacement: 5 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the nine M2 x 4mm flat head screws located on the outer edges on the back of the laptop.
    • Make sure to keep these screws separated from future screws that will be disassembled throughout this process.
  6. Lenovo S20-30 Keyboard Replacement: 6 단계, 이미지 1/2 Lenovo S20-30 Keyboard Replacement: 6 단계, 이미지 2/2
    • Use the long metal spudger to pry open the bottom half of the laptop.
    • Gently lift the cover off to reveal the motherboard.
  7. Lenovo S20-30 Keyboard Replacement: 7 단계, 이미지 1/2 Lenovo S20-30 Keyboard Replacement: 7 단계, 이미지 2/2
    • Remove the four M2 x 3mm flat-head screw using a Phillips #000 screwdriver.
  8. Lenovo S20-30 Keyboard Replacement: 8 단계, 이미지 1/2 Lenovo S20-30 Keyboard Replacement: 8 단계, 이미지 2/2
    • Flip over laptop and open the lid to have access to the keyboard.
    • Use a plastic opening tool to pry apart the keyboard.
  9. Lenovo S20-30 Keyboard Replacement: 9 단계, 이미지 1/3 Lenovo S20-30 Keyboard Replacement: 9 단계, 이미지 2/3 Lenovo S20-30 Keyboard Replacement: 9 단계, 이미지 3/3
    • A connector is attached to the keyboard.
    • Remove it by gently pulling it outward.
  10. Lenovo S20-30 Keyboard Replacement: 10 단계, 이미지 1/1
    • Grab replacement keyboard to insert back into place.
결론
다른 3명이 해당 안내서를 완성하였습니다.
ILEANISSE SOTO
회원 가입일: 10/01/18
187 평판
안내서 1개 작성함
McKendree University, Team S1-G4, Quinn Fall 2018 McKendree University, Team S1-G4, Quinn Fall 2018 회원
MCKU-QUINN-F18S1G4
2 회원들
안내서 3개 작성하였습니다
댓글 한 개
where can i find a replacement keyboard/ or what model # do i need?
ed paz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 20
전체 시간: 1,225
