주요 콘텐츠로 건너뛰기
소개
The screen on the Lenovo Tab 2 A10-70 is a pain in the tush to remove but if you can get past the adhesive it's not to hard!!!! Don't Give up. (Please excuse the pictures in this guide, the preggo body looks even bigger in them!!!!)
부품
지정된 부품이 없습니다.
  1. It is extremely easy to remove the plastic casing. Just slide your spudger (or fingernail if they are strong) around the edge to remove It is extremely easy to remove the plastic casing. Just slide your spudger (or fingernail if they are strong) around the edge to remove
    • It is extremely easy to remove the plastic casing. Just slide your spudger (or fingernail if they are strong) around the edge to remove
  2. Using your fingernail or tweezers lift the holding flap and disconnect the digitizer cable for the old screen
    • Using your fingernail or tweezers lift the holding flap and disconnect the digitizer cable for the old screen
  3. Please be very careful!, This glass shatters easily and shards will go flying if you are rough The glass is connected to the frame and LCD by the world's strongest adhesive, .... took me well over an hour to remove the old screen Using a heat gun (high powered blow dryer) or those of you lucky enough to have an iopener kit slowly heat your way around the glass, start in a corner and work your spudger in.
    • Please be very careful!, This glass shatters easily and shards will go flying if you are rough
    • The glass is connected to the frame and LCD by the world's strongest adhesive, .... took me well over an hour to remove the old screen
    • Using a heat gun (high powered blow dryer) or those of you lucky enough to have an iopener kit slowly heat your way around the glass, start in a corner and work your spudger in.
    • Make sure you slide your spudger straight in to avoid the lcd There is a nice gap but the adhesive is two part!
    • Clean your Edges
    • Using your spudger or a razor knife clean off any left behind adhesive
  4. Carefully Slide the digitizer cable through the opening in the case Flip over case and reconnect the new digitizer cable
    • Carefully Slide the digitizer cable through the opening in the case
    • Flip over case and reconnect the new digitizer cable
    • I then tested to make sure the screen and digitizer worked before adhesive :)
  5. The Screen I ordered came with adhesive already on it, but I added some 3M tape too Press the Screen firmly into place
    • The Screen I ordered came with adhesive already on it, but I added some 3M tape too
    • Press the Screen firmly into place
    • Then replace the back cover!
  6. Test your work and Be proud, not an easy task but you completed it!!!!
    • Test your work and Be proud, not an easy task but you completed it!!!!
결론
다른 18명이 해당 안내서를 완성하였습니다.
Amber Wooldridge
회원 가입일: 2015년 12월 09일
539 평판
안내서 1개 작성함
댓글 9개
Hi Amber,
Thank you for the guide.
How's the replacement screen quality? Can I know where you bought the screen from? I need to replace my screen. Thinking of buying it from the same supplier. Would want a screen with adhesive too.
Thanks
Richard.
richardeugenio - 답글
I don't quite know but it looks like a regular bootleg one
Sergio Palacio -
I just completed this, using a proper heat Gun it took about 10 minutes.
Ebay screen, oem tagged, apparently no adhesive on it.
Philip Wiberg - 답글
I love the guide and you have encouraged me to try to replace my screen. Where did you order the replacement screen and did you order just the new glass?
Thanks,
Jack
Jack Wilson - 답글
did you replace the glass/digitiser only, or did you also replace the lcd ? the title suggests glass/digitiser but step 6 refers to a "new screen" sorry for the confusion
karmatosednz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 29
전체 시간: 42,070
