주요 콘텐츠로 건너뛰기
Lenovo Tab 2 A10-70 Power Button Replacement
필요한 것
  1. Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: 1 단계, 이미지 1/2 Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: 1 단계, 이미지 2/2
    • Use a plastic opening tool to pry open the back cover of the tablet.
  2. Lenovo Tab 2 A10-70 Power Button Replacement: 2 단계, 이미지 1/1
    • The power button strip is only held in place by a small piece of double-sided tape.
    • Gently use the precision tweezers to separate the power button strip from the interior frame of the tablet.
  3. Lenovo Tab 2 A10-70 Power Button Replacement: 3 단계, 이미지 1/1
    • Be careful with the soldering iron to avoid injury.
    • Remove the power button from the motherboard.
    • Use the soldering iron to heat up the connections. Gently pull away from the motherboard after connections are detached.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tyler Hagenlocher
회원 가입일: 02/08/16
350 평판
안내서 2개 작성하였습니다
USF Tampa, Team 12-6, Eyestone Spring 2016 USF Tampa, Team 12-6, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S12G6
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Thank you for making this helpfull instrutions.
Where i can get the Buttons?
Simon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 26
전체 시간: 6,768
