주요 콘텐츠로 건너뛰기
Lenovo Tab 2 A10-70 Rear Facing Camera Replacement
필요한 것
  1. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement, Rear Facing Camera: 1 단계, 이미지 1/1
    • Before removing the camera, make sure the device is powered off
    • Use a plastic opening tool to pry open the back cover of the tablet..
  2. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: 2 단계, 이미지 1/1
    • Locate the cable that is connecting the camera to the tablet
  3. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: 3 단계, 이미지 1/1
    • Disconnect the cable that is connecting the camera to the tablet
  4. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: 4 단계, 이미지 1/2 Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: 4 단계, 이미지 2/2
    • Simply remove the camera from the tablet by lifting it up
    • Repeat Steps in reverse order with a new camera for reassembly
결론
Tyler Hagenlocher
회원 가입일: 02/08/16
350 평판
안내서 2개 작성하였습니다
USF Tampa, Team 12-6, Eyestone Spring 2016 USF Tampa, Team 12-6, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S12G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 880
