주요 콘텐츠로 건너뛰기
Lenovo Tab 2 A7-20F Battery Replacement
필요한 것
  1. Lenovo Tab 2 A7-20F Battery Replacement, Case: 1 단계, 이미지 1/2 Lenovo Tab 2 A7-20F Battery Replacement, Case: 1 단계, 이미지 2/2
    • Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
  2. Lenovo Tab 2 A7-20F Battery Replacement, Battery: 2 단계, 이미지 1/2 Lenovo Tab 2 A7-20F Battery Replacement, Battery: 2 단계, 이미지 2/2
    • The battery is connected to the motherboard by the thin wire shown here.
    • Pull up gently on the yellow tape to access the connector.
  3. Lenovo Tab 2 A7-20F Battery Replacement: 3 단계, 이미지 1/1
    • Gently detach the connector from the motherboard by pulling up on it.
  4. Lenovo Tab 2 A7-20F Battery Replacement: 4 단계, 이미지 1/3 Lenovo Tab 2 A7-20F Battery Replacement: 4 단계, 이미지 2/3 Lenovo Tab 2 A7-20F Battery Replacement: 4 단계, 이미지 3/3
    • There is double-sided tape inside the case.
    • Use the spudger tool to loosen the bond of the adhesive from the double sided tape.
    • Separate the battery from the case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Thanh
회원 가입일: 09/21/17
345 평판
안내서 3개 작성하였습니다
Washington State, Team S5-G111, Phelps-Hillen Fall 2017 Washington State, Team S5-G111, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S5G111
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 28
전체 시간: 2,997
