소개
Without a heat gun this job is vastly more delicate of a procedure than with a heat gun to loosen the adhesive the attaches the screen to the case.
필요한 것
Use a plastic opening tool or a tweezer to remove any tape.
Unplug the electrical connectors by lifting the clip that hold them in place.
Use the plastic opening tool to lift up the camera lens starting from the left side between the gap.
Remove the metal tape that connects the camera lens to the panel in order to remove the camera lens.
Use the heat gun to loosen the adhesive around the perimeter of the screen(the solid black section).
The spudger tools can then be slowly worked under the screen to gradually lift it away from the case.
At this point there are still a few strips of silver tape holding the digitizer in place.
Remove these pieces and the digitizer should slip right out of the case.
