주요 콘텐츠로 건너뛰기
Lenovo Tab 2 A8 Audio/Video Port Replacement
필요한 것
  1. Lenovo Tab 2 A8 Audio/Video Port Replacement, Removing the Back Panel: 1 단계, 이미지 1/3 Lenovo Tab 2 A8 Audio/Video Port Replacement, Removing the Back Panel: 1 단계, 이미지 2/3 Lenovo Tab 2 A8 Audio/Video Port Replacement, Removing the Back Panel: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Audio/Video Port Replacement: 2 단계, 이미지 1/3 Lenovo Tab 2 A8 Audio/Video Port Replacement: 2 단계, 이미지 2/3 Lenovo Tab 2 A8 Audio/Video Port Replacement: 2 단계, 이미지 3/3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Audio/Video Port Replacement, Motherboard: 3 단계, 이미지 1/3 Lenovo Tab 2 A8 Audio/Video Port Replacement, Motherboard: 3 단계, 이미지 2/3 Lenovo Tab 2 A8 Audio/Video Port Replacement, Motherboard: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using the Phillips #000 screwdriver, remove the four M1.4 × 2.5 screws holding the motherboard in place.
    • Because the screws are small, it is a good idea to remove them with a pair of tweezers.
  4. Lenovo Tab 2 A8 Audio/Video Port Replacement: 4 단계, 이미지 1/3 Lenovo Tab 2 A8 Audio/Video Port Replacement: 4 단계, 이미지 2/3 Lenovo Tab 2 A8 Audio/Video Port Replacement: 4 단계, 이미지 3/3
    • Remove the M1.4 × 2.5 screw securing the battery lead to the battery with the Phillips #000 screwdriver.
    • With a pair of tweezers, gently move the battery lead so it will not obstruct the motherboard.
    • With a pair of tweezers, carefully unplug the strip connecting the screen to the motherboard.
    • The strip connecting the screen to the motherboard is firmly in place and may require some careful use of strength to unplug it.
  5. Lenovo Tab 2 A8 Audio/Video Port Replacement: 5 단계, 이미지 1/1
    • Remove the motherboard by lifting the top edge and pulling outward to free it from the small tabs that hold it in place.
    • The small tabs can be broken if the motherboard is pried up too forcefully.
    • The button tabs are fastened to the motherboard by a small adhesive strip. Take care in removing the motherboard to avoid tearing the wires.
  6. Lenovo Tab 2 A8 Audio/Video Port Replacement, Audio/Video Port: 6 단계, 이미지 1/2 Lenovo Tab 2 A8 Audio/Video Port Replacement, Audio/Video Port: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Flip the motherboard to its back side.
    • Desolder the six audio/visual port contact points.
    • Use tweezers to remove the existing audio jack to remove from the motherboard entirely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Taylor Smith
회원 가입일: 01/26/17
382 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-4, Baechle Spring 2017 IUPUI, Team 2-4, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S2G4
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 584
