주요 콘텐츠로 건너뛰기
Lenovo Tab 2 A8 Battery Replacement
필요한 것
  1. Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: 1 단계, 이미지 3개 중 1개 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: 1 단계, 이미지 3개 중 2개 Lenovo Tab 2 A8 Battery Replacement, Removing the Back Panel: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Battery Replacement: 2 단계, 이미지 3개 중 1개 Lenovo Tab 2 A8 Battery Replacement: 2 단계, 이미지 3개 중 2개 Lenovo Tab 2 A8 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 Lenovo Tab 2 A8 Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using a counterclockwise motion with the Phillips #000 screwdriver, remove the M1.4 × 2.5 screw that holds down the copper strip connected to the battery.
    • With a pair of Tweezers, carefully unplug the strip connecting the battery to the motherboard.
  4. Lenovo Tab 2 A8 Battery Replacement: 4 단계, 이미지 3개 중 1개 Lenovo Tab 2 A8 Battery Replacement: 4 단계, 이미지 3개 중 2개 Lenovo Tab 2 A8 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Working your way around the edge of the battery, pry out the battery using a plastic opening tool
    • Be aware that the battery is held in by double-sided tape on the underside
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Carli Ollerman
회원 가입일: 10/08/15
263 평판
안내서 1개를 작성함
2가이드 댓글
Thanks... but where do we find a replacement battery?
sebtrudel - 답글
I fixit might have a replacement battery
storm builder - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 49
전체 시간: 12,102
