소개
This guide illustrates the procedure to remove the front-facing camera of your device.
필요한 것
이 단계에 사용된 도구:Tweezers$4.99
Place the tablet face down on a soft, stable surface that will protect the screen.
Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
Using tweezers, peel off the anti-static sticker from the camera connection port.
다른 3명이 해당 안내서를 완성하였습니다.
