주요 콘텐츠로 건너뛰기
Lenovo Tab 2 A8 Speaker Replacement
필요한 것
  1. Lenovo Tab 2 A8 Speaker Replacement, Removing the Back Panel: 1 단계, 이미지 3개 중 1개 Lenovo Tab 2 A8 Speaker Replacement, Removing the Back Panel: 1 단계, 이미지 3개 중 2개 Lenovo Tab 2 A8 Speaker Replacement, Removing the Back Panel: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Speaker Replacement: 2 단계, 이미지 3개 중 1개 Lenovo Tab 2 A8 Speaker Replacement: 2 단계, 이미지 3개 중 2개 Lenovo Tab 2 A8 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Speaker Replacement, Speaker: 3 단계, 이미지 3개 중 1개 Lenovo Tab 2 A8 Speaker Replacement, Speaker: 3 단계, 이미지 3개 중 2개 Lenovo Tab 2 A8 Speaker Replacement, Speaker: 3 단계, 이미지 3개 중 3개
    • Using a counterclockwise motion with the Phillips #000 screwdriver, unscrew the three M1.4 × 2.5 screws that hold the white plastic speaker housing in place.
    • Pry off the speaker housing utilizing a metal spudger.
  4. Lenovo Tab 2 A8 Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Insert a plastic probe through the tab and pry to remove the speaker from its socket.
    • Be careful not to damage the wires attached to the speaker. Don't forcibly remove the speaker from its socket. The speaker is magnetic, don't use metal tools.
  5. Lenovo Tab 2 A8 Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Using a soldering iron, desolder the contacts that connect the speaker wires to the speaker chip.
결론
작성자
4다른 기여자 명과 함께
Tim Gales
회원 가입일: 10/06/15
478 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 764
